On Wed, Dec 20, 2000 at 04:21:50PM +0100, mlennert@club.worldonline.be wrote:
> What's the news on r.support ? In the current CVS version it does not seem to
> be included, and on the web page it is marked as needing updating.
> In the meantime, do I have to edit the category file by hand ?
Hi Moritz,you have to CVS update r.support like that:
cvs up -dP src/raster/r.support
Then it will appear again in your copy (I have splitted the code into
cmd/ and inter/ subdirectories).Cheers
Thanks, now it works. I just had the following problem compiling:
I first tried to compile from the src/display/r.support directory. I got the
following error message:
/usr/local/src/cvs/grass/src/raster/r.support/cmd
make -f OBJ.i686-pc-linux-gnu/make.rules
make[1]: Entering directory `/usr/local/src/cvs/grass/src/raster/r.support/cmd'
make[1]: *** No rule to make target `/usr/local/grass5/etc/modhist', needed by
`all'. Stop.
make[1]: Leaving directory `/usr/local/src/cvs/grass/src/raster/r.support/cmd'
make: *** [all] Error 1
Then I went into the ./cmd directory and tried to compile in there:
make: *** No rule to make target `/usr/local/grass5/etc/modhist', needed by
`all'. Stop.
Then I went into the ./inter directory; which compiled fine. And, after that
compiling in the ./cmd directory worked as well.
Moritz
subject 'unsubscribe grass5'
