Hi Frank,
[cc to GRASS 5]
On Wed, Mar 21, 2001 at 10:08:33AM -0500, Frank Warmerdam wrote:
Markus Neteler wrote:
> Thanks, Frank!
> Of course it will be included in the next binary package.
> Additionally we would need Solaris/SUN, Solaris/Intel and SGI
> versions, hopefully you can get volunteers to build that for you.
> The addition of this lib is documented in the release rules for
> GRASS binaries.
Markus, et al,
I have made IRIX 6.5, and Solaris 2.7 shared libaries available in the
same place.
http://gdal.velocet.ca/projects/grass/index.html
Great, this is perfect for the other binary releases of GRASS.
I would be happy to help anyone interested in building for Solaris/INTEL,
MacOS X, Cygwin, etc. Let me know if the files I have created don't work
properly.
Best regards,
Frank, there might be a related problem due to the
libstdc++-libc6.2-2.so.3
stored in
$GISBASE/lib
for libgdal.
Several people have reported this error:
BUG IN DYNAMIC LINKER ld.so: dl-version.c: 210: _dl_check_map_versions:
Assertion 'needed != ((void *)0)' failed!
for nviz and r3.showdspf. I am not sure about this bug, but can it be
caused by the LD_LIBRARY_PATH? Probably nviz catches the wrong libstdc?
There seems to be a time coincidence with us adding the LD_LIBRARY_PATH into
$GISBASE/etc/Init.sh and above bug.
Regards
subject 'unsubscribe grass5'
stored in
$GISBASE/lib
for libgdal.
Markus,
Does this problem go away if the libstdc .so is removed from $GISBASE/lib?
Are nvis, and r3.showdspf C++ programs?
The c++ library is only required within $GISBASE/lib if it isn't available
on the system. I thought it would be pretty harmless to include under the
assumption it should be essentially the same as system provided copies, but
I could be wrong. Perhaps we should "hide" the c++ shared library and only
have users rename it to the real name if it turns out they need it.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
> stored in
> $GISBASE/lib
> for libgdal.
Markus,
I have just suggested this to those users (I can't reproduce the bug here).
Let's wait for their answers.
On my machine I have (Suse Linux 7.0):
locate libstdc
/usr/lib/gcc-lib/i486-suse-linux/2.95.2/libstdc++.a
/usr/lib/gcc-lib/i486-suse-linux/2.95.2/libstdc++.so
/usr/lib/libstdc++-3-libc6.1-2-2.10.0.a
/usr/lib/libstdc++-3-libc6.1-2-2.10.0.so
/usr/lib/libstdc++-libc6.1-1.so.2
/usr/lib/libstdc++-libc6.1-2.a.3
/usr/lib/libstdc++-libc6.1-2.so.3
/usr/lib/libstdc++-libc6.2-2.so.3
/usr/lib/libstdc++.so.2.7.2
/usr/lib/libstdc++.so.2.8
/usr/lib/libstdc++.so.2.9
/usr/local/grass5/lib/libstdc++-libc6.2-2.so.3
Could this be done on install time using "ldd" or something else on
r.in.gdal? BTW: It's suprising that the version number is coded and no
libstdc++.so -> libstdc++.so.2.9
or whatever link exists - at least for me this unusual, but obviously common
for libstdc++
Regards
