[GRASS5] Re: [GRASSLIST:1768] Re: realtime_gps
On Saturday 15 November 2003 15:46, Paul Kelly wrote:
Hello
On Sat, 15 Nov 2003, Maliheh wrote:
> Thank you so much Hamish for your help.
> but in grass5.7 when I use g.projinfo it shows:
> can't read "opttype(1)":no such element in array
> Now what should I do?
Don't use g.projinfo in 5.7; use the newer g.proj. Specifically,
"g.proj -jf" will give you the projection parameters for your current
location in PROJ.4 format. Type "g.proj help" to see the other options
(there is no man page yet).
Paul
Should I remove grass51/scripts/g.projinfo/ ?
Radim
Hello Radim
I can confirm that I intended g.proj as a replacement for g.projinfo (and
ultimately also g.setproj...in a few years!), so if you are happy with the
behaviour of g.proj so far, go ahead and remove g.projinfo
Paul
Which is the graphics library used for building Nviz ???
Vidya.
"You rarely succeed at anything, unless you have fun doing it."
Kotamraju Vidya
Marine HydroDynamics Lab,
Physical Oceanography Division,
National Institute of Oceanography,
Dona Paula, Goa 403 004, India.
Ph.: +91-832-2450400 (O)
      +91-832-2541756 (R)
e-mail: vidyakr@darya.nio.org
That depends upon what you mean by "graphics library". The GUI uses
Tcl/Tk; the rendering is done by the OGSF library in src/libes/ogsf,
which uses OpenGL.
