On Wednesday 26 November 2003 20:38, you wrote:
I think I have everything configured properly for an OSX build,
however, I get the following errors. Any ideas? I scanned the list
archives, but did not find anything helpful:cd OBJ.powerpc-apple-darwin7.0.0;
LD_LIBRARY_PATH=:/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-
apple-darwin7.0.0/lib ./test
ERROR in read/write portable short
Written: -32768
Read : 0
Written: -12345
Read : -57
Written: 12345
Read : 57
Written: 32767
Read : -1
make[3]: *** [OBJ.powerpc-apple-darwin7.0.0/test] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
I read in the list, that LD_LIBRARY_PATH does not work on MacOSX,
and DYLD_LIBRARY_PATH should be used instead. Did you set
DYLD_LIBRARY_PATH to /usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/lib
before somehow? Otherwise it should not work.
Do you have 5.7 only? Are you sure that 5.0 libraries are not
used (are not in DYLD_LIBRARY_PATH) instead of 5.7 libraries?
Try also
ldd /usr/local/src/grass57_exp_2003_11_22/lib/vector/diglib/OBJ.powerpc-apple-darwin7.0.0/test
On little endian
dec hex
-32768 = 00 80
-12345 = C7 CF
12345 = 39 30
32767 = FF 7F
dec hex
0 = 00
-57 = FF C7
57 = 39
-1 = FF FF
So it seems that 2. byte is lost.
This will be a bug in diglib, it was developed on intel and probably never run on Power PC.
I updated grass51/lib/vector/diglib/test.c so that it prints byte order also,
please update from cvs or download from web
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass51/lib/vector/diglib/test.c?rev=1.7&content-type=text/plain
then recompile diglib and send us your new error report (should include " ... byte_order = ... "),
usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/include/portable.h and
usr/local/src/grass57_exp_2003_11_22/lib/vector/diglib/test.tmp (gzipped)
By chance, anybody knows how long type 'short' is on Power PC, and which endian.
Paul, you have 5.7 compiled on some non intel platforms, can you send us your
portable.h files for those machines also?
Radim
