[GRASS5] Re: [GRASSLIST:2530] Re: v.in.ogr not building on Linux
chris@fonnesbeck.org wrote:
Forcing v.in.ogr to compile results in the following error:
make: ***
[/usr/src/grass57_exp_2003_12_06/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.ogr]
Error 1
Thinking about it again I suppose also you would need to manually edit
include/config.h and uncomment the line
/* #define HAVE_OGR */
But it would be much better to find out what's causing the problem. I
thought perhaps something has changed recently to introduce a bug but I
didn't seem to be able to access the CVS server at Intevation yesterday
to check. Maybe Markus would know if anything has changed.
Paul
make: ***
Error 1
This line is already uncommented. Here is the relevant section of the configure file:
if test "$GDAL_CONFIG" != "" ; then
   GDAL_LIBS="`$GDAL_CONFIG --libs`"
   GDAL_CFLAGS="`$GDAL_CONFIG --cflags` -DUSE_GDAL_H"
   USE_GDAL=1
   if test `$GDAL_CONFIG --ogr-enabled` = "yes" ; then
     cat >> confdefs.h <<\EOF
#define HAVE_OGR 1
EOF
     USE_OGR=1
   fi
else
   GDAL_LIBS=$DLLIB
   GDAL_CFLAGS=
   USE_GDAL=
   USE_OGR=
fi
When I type "gdal-config --ogr-enabled", it returns "yes", so it sonds like a bug to me.
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
> make: ***
> Error 1
It's unchanged for some days. I recompiled the entire 5.7 from
scratch today, no problem.
