[GRASS5] Re: [GRASSLIST:2717] How to get topology of area edges
    I'm attempting to read GRASS's ascii vector output into a graphics
display program that I'm writing... I produce this output (with
v.out.ascii) from a valid GRASS vector layer containing area polygons.
What appears in the resulting data file is a line that denote an area
and a number of points followed by these points... i.e.
A 4
easting northing
easting northing
note that should read
A 4
northing easting
northing easting
northing easting
northing easting
as long as the file format (and vectors in general) is changing for 5.7,
is it too confusing to switch to x,y? maybe with an added header line
"FORMAT: X,Y" or something? Now would be the time if we are ever going
to fix that...
Hamish
> A 4
> easting northing
> easting northing
A 4
northing easting
northing easting
northing easting
northing easting
to fix that...
"FORMAT: X,Y" is good idea, but still could make much confusion, there
are many scripts working with ascii format.
Maybe another directory?
Radim
> > polygons. What appears in the resulting data file is a line that
> > denote an area and a number of points followed by these points...
> > i.e.
> > A 4
> > easting northing
> > easting northing
> A 4
> northing easting
> northing easting
> northing easting
> northing easting
> 5.7, is it too confusing to switch to x,y? maybe with an added
> header line"FORMAT: X,Y" or something? Now would be the time if we
> are ever going to fix that...
I agree about the creating confusion. BUT the existing way creates confusion
too. Question is, which way causes LESS confusion and is easier to work on
in the future?
Will those 5.0 scripts not break & need updating to work with the new 5.7 ascii
format anyway?
Moving things into the vector/ directory just cleaned things up, do we
really want to go back and add more clutter?
Hamish
> > > graphics
> > > points... i.e.
> > > A 4
> > > easting northing
> > > easting northing
> > A 4
> > northing easting
> > northing easting
> > northing easting
> > northing easting
> > for 5.7, is it too confusing to switch to x,y? maybe with an added
> there are many scripts working with ascii format.
confusion too. Question is, which way causes LESS confusion and is
easier to work on in the future?
5.7 ascii format anyway?
[replying to myself..]
... maybe make an "ascii" file in the new vector/$MAPNAME/ directory for
the changed format. Putting new 5.7 data in dig_ascii/ seems wrong.
That should be reserved for old GRASS 5.0 files.. Otherwise we never get
away from the dig_* directory clutter even when 5.0 is history.
This would allow us to change the file format more drastically too: e.g.
do we really have to specify how many vertices will follow each feature?
L 341
y1 x1
y2 x2
y341 x341
is a pain to do; r.in.poly format is much easier to deal with for making
quick & simple custom import filters, as I do for Matlab->GRASS..
What about:
A 341
x1 y1 double_1a double_1b "label_1a" "label1b"
x2 y2 double_2a double_2b "label_2a" "label2b"
x341 y341 double_341a double_341b "label_341a" "label341b"
seems more logical to me than a huge att table at the end.....??
WEST EDGE: etc are also a pain to have to figure out. Couldn't we do this
in code? Or maybe that is useful for setting up new mapset regions..
maybe meta-data could move to "vector/$MAP/hist" too? Maybe not, self-
contained in one file can be good I guess.
just some ideas,
Hamish
I don't like vector/$MAPNAME/ascii, vector/$MAPNAME/ should be used only for
binary format, I think. You are right that old scripts cannot read new
format anyway. What about vector_ascii/?
v.out.ascii has already -o flag, the same could have v.in.ascii.
L 341
y1 x1
y2 x2
y341 x341
I agree that number of coordinates is something redundant, on the other hand,
it is form of check and makes the format more 'robust'.
What about:
A 341
This I don't understand.
Which 'att table' at the end?
I think that v.in.ascii works without 'WEST EDGE' even in 5.0.
In 5.7 is always calculated when topology is built and cannot be changed manualy.
For me, all these changes are not enough important. I am not against,
but I'll not do that. Go on and do that if you want.
I would only oppose ascii in vector/$MAP/.
Radim
Radim
v.{in,out}.ascii should behave like other in/out programs, and treat
the in/out (respectively) parameter as a filename, not a map name.
Simple names should be relative to the current directory.
No dig_ascii/vector_ascii directory, no $MAPNAME/ascii file. IOW, just
like v.{in,out}.<everything else>.
