(sorry if this appears twice, I sent it out with the wrong sender address
at first)
On Tue, 1 Jan 2002, Eric G. Miller wrote:
<clipped>
Alright, the problem seems to be that in "exec.c", G_put_cellhd() is
called after the raster has been written. I think it is entirely
unnecessary (and obviously screws up some critical info). I created
an integer test file (floats didn't seem to be affected), and after
commenting the G_put_cellhd() call, the rectified image doesn't
cause a segfault. Would others care to try... ?
It seems to work here
Frank
It's around, line 75 or so...
if (rectify (name, mapset, result,order))
select_target_env();
/* G_put_cellhd (result,&target_window); */
if(cats_ok)
Eric G. Miller <egm2@jps.net>
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
HI! I'm a .signature virus! cp me into your .signature file to help me spread!
