Glynn Clements wrote:
Richard Greenwood wrote:
Regarding "d.mon png" I added gd to 5.0.3 but it still did not work. I also tried it under 5.3 (which supposedly does not require gd) and it did not work there either.
Also tried adding fftw as recommended at:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/documents/release_rules.txt
But failed to get it working either.Can you provide more details regarding what went wrong?
I have built both the PNG driver and the programs which require FFTW
under Cygwin.
I could not find FFTW as part of the Cygwin binary distribution system, so I downloaded, built and installed FFTW 2.1.5, and enabled FFTW in my GRASS 5.0.3 configure. The following is the compilation error log. I assume all these failed due to FFTW problem.
GRASS GIS compilation log
Start of compilation: Sun Mar 7 15:51:03 MST 2004
Errors:
Compilation error in module: src/imagery/i.fft (ignored)
Compilation error in module: src/imagery/i.zc (ignored)
Compilation error in module: src/raster/r.surf.fractal (ignored)
Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
End of compilation: Sun Mar 7 16:00:22 MST 2004
DONE generating GRASS GIS binary code
Regarding PNG, I installed the current gd and libgd via the Cygwin setup program, enabled gd (and png) in my 5.0.3 configure, and received no errors. However running GRASS:
GRASS:~ > d.mon png
ERROR: no such monitor 'png'
No such monitor as 'png'
Problem selecting png. Will try once more
I recall an earlier email from you in which you said gd was no required in 5.3, however I get exactly the same error as above in 5.3.
Nviz question: With what versions of GRASS is it appropriate to use and distribute the Cygwin NVWISH2.2 that you provided?
What would be merits of enabling proj? Although I have it installed under Cygwin, GRASS configure fails when I try to enable proj.
Rich
Richard Greenwood
www.greenwoodmap.com
