Sabine Grabner wrote:
i made 'make install' and had a look to /usr/local/bin to check my
new command to run grass-5.7.0.what i found was:
-rwxr-xr-x 1 root root 1173 2004-01-26 15:57 grass5
lrwxrwxrwx 1 root root 33 2004-05-12 09:57 grass57 -> /usr/
local/bin/grass57-10_05_2004
-rwxr-xr-x 1 root root 1170 2004-06-30 10:05 grass57-10_05_2004
-rwxr-xr-x 1 root root 2391 2004-01-26 15:57 grass5uninstall.shi am wondering if my old command grass57-10_05_2004 is now
overwritten as the date is doday's?
Yes. The "install" target generates the script using shell
redirection:
-sed -e "s#^GISBASE.*#GISBASE=${INST_DIR}#" ${ARCH_BINDIR}/grass${VERSION_MAJOR}${VERSION_MINOR} > ${BINDIR}/grass${VERSION_MAJOR}${VERSION_MINOR}
This will overwrite any existing target.
[Developers: the correct fix is to create a temporary file and then
install it using the INSTALL variable which is set by autoconf's
AC_PROG_INSTALL macro. That will be the path to the "install" program
if it is found, or the "install-sh" script otherwise. Both of these
would have replaced the symlink with the new script rather than
overwriting the symlink's target.]
is 'grass57-10_05_2004' executing 'grass57-10_05_2004' or 'grass-5.7.0' now?
It will have been updated. It's a script, so you can see what it
contains. It just sets GISBASE then executes Init.sh.
