[GRASS5] Re: [GRASSLIST:3968] 5.7 v.in.ascii
> cat mpa.vector | v.in.ascii -t out=mpa
anybody mind if I update 5.7's v.in.ascii to have a delim= option? Looks
pretty straight forward; would allow input directly from .csv files from
a spreadsheet which I think would help out the non-awk/cut/sed/regex
folks quite a bit..
Hamish
folks quite a bit..
s.in.ascii,s.out.ascii,db.select,d.what.rast,r.cats,r.distance,r.stats,d.colorlist:
fs field separator
Radim
> Looks pretty straight forward; would allow input directly from .csv
> files from a spreadsheet which I think would help out the
> non-awk/cut/sed/regex folks quite a bit..
s,d.colorlist:
fs field separator
ok, done.
Hamish
