[GRASS5] Re: [GRASSLIST:3982] Re: GLIBC_2.2 not found
[CC'd to GRASS5]
Steve Kimball wrote:
I'm also runnig Red Hat 6.2 and got
  r.in.ascii: /lib/libc.so.6: version 'GLIBC_2.2` not found (required
for r.in.ascii)
You would either have to install glibc 2.2 (RH6.2 uses glibc 2.1), or
obtain a binary package which was intended for RH6.2 (or another
distribution which uses glibc 2.1).
Programs which were compiled for RH7.x will almost never work on
RH6.x, due to the different version of glibc.
Hmm. If this is the package from grass.itc.it, i.e.
http://grass.itc.it/grass5/binary/linux/grass5.0.0pre3_i686-pc-linux-gnu_bin.tar.gz
then the README (which claims that it requires glibc 2.1) is
incorrect.
On Fri, Jun 28, 2002 at 11:22:43PM +0100, Glynn Clements wrote:
[CC'd to GRASS5]
> for r.in.ascii)
incorrect.
I have fixed the README, it should show up by tomorrow.
