It seems that there is not option in v.digit -> edit
to join two lines that share a node.
Is there a reason for this in the data model?
It should be fairly easy to do.
Like if I have two lines .= vertices X=node shared by both lines
.----.----X--.--.
to join the lines to
If I wanted to add this, what would I have to do?
On Thu, Aug 22, 2002 at 10:21:58AM +0200, Monika Schunke wrote:
I cannot find any tool to merge vectorlines. Does not GRASS have any
tools for that?
.----.----X--.--.
Here 'snapping' should help. Either v.support or v.digit,
select a very small threshold.
> tools for that?
> .----.----X--.--.
We tried out to use either v.support or v.digit but snapping only
snaps 2 nodes to 1 single node (or to 2 nodes at the same
location).
We would rather like to convert a node, shared by 2 lines, to a
vertex
of a single line (like Bernhard tried to demonstrate).
Any suggestions? Or perhaps any reason why it isn't sensible to do
so?
Silke
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
No.
You can do that (some check for different categories should be done).
> > .----.----X--.--.
location).
vertex
so?
v.build.polylines
Radim
Radim,
thanks for the answers.
No.
> so?
v.build.polylines
