[GRASS5] Re: [GRASSLIST:4542] Re: turnoff tcl/tk interface
Paul Kelly wrote:
> mapset / location / etc... but does nothing for commands that I might issue
> afterwards (e.g. r.in.gdal, r.colors, etc...) these interfaces still
> pop-up...
> Can someone tell me what the magic incantation is to get all these gui's
> to stop popping up?
I take it you're using 5.7? Setting the environment variable GRASS_UI_TERM
to anything should stop this. Note that the tcltkgrass menu entries won't
work if you have this set, as they assume it isn't set.
tcltkgrass should explicitly unset this variable.
