[GRASS5] Re: [GRASSLIST:4543] r.digit failed once
Maciek Sieczka wrote:
r.digit gave me once a following error but I can't (happily :)) reproduce it
anymore
(precompiled 5.7 09_10_2004)
maybe worthy of fixing
invalid command name ".dialog1.pw.f1.frame.win.text"
    while executing
"$outtext insert end $str"
This suggests that the Tcl/Tk dialog has been destroyed before the
process has finished generating output.
I'm not sure how to handle this, e.g. whether to kill the process, or
change the the fileevent handler on the process output to one which
simply discards all output, or block until the process completes, or?
