Then the problem is that bounding box of that long boundary
intersects all the islands and v.in.ogr will try to break those
lines which takes long time. It was already discussed here. Try to
modify v.in.ogr so that it writes long boundaries in more shorter
parts.
Radim (11 Feb 2004):
I have got idea. Split boundaries to smaller parts, something like
for ( line = 1; line <= Vect_get_num_lines ( In ); line++) {
type = Vect_read_line ( In, Points, Cats, line);
v = 0;
while ( v < Points->n_points ) {
Vect_reset_line (OPoints);
for (i = 0; i < maxvertex && v < Points->n_points )
Vect_append_point ( OPoints, Points->x[v], Points->y[v], 0);
Vect_write_line (Out, type, Points, Cats);
Could you try it? If it helps, it would be reasonable to add this
splitting to v.in.ogr / v.clean.
I am just working through the same data with v.buffer. Again, very slow.
where should I put the above code? lib/vector/Vlib/break_lines.c ?
or in each module, e.g. v.in.ogr? if so then at what point in the
processing?
parts.
v = 0;
for (i = 0; i < maxvertex && v < Points->n_points ) Vect_append_point ( OPoints, Points->x[v], Points->y[v], 0);
processing?
In break_lines.c surely not. It should go to v.in.ogr where the boundary (GV_BOUNDARY only) is written the first time, i.e. geom.c line 222 and 245.
