In fact NO version of gdal is PROVIDED with GRASS. If you compile GRASS, you
need to first compile gdal. At that point, you can include HDF support in
gdal. That is, r.in.aster won't work if gdal is not compiled with HDF
support.
What you are probably referring to are the gdal binaries provided with a set
of cygwin-compatible binaries. These are done by volunteers who maintain
binaries for different platforms. Windows has been particularly problematic
because 1) Windows is somewhat more complicated by needing Cygwin and 2)
relatively few GRASS users use it on Windows (this is a catch-22 situation;
if it were easier to use on Windows, more Windows folks would use it, hence
more Windows-savvy developers working on it).
Very recently, Huidae Cho has made enormous improvements in the way that the
Windows version is installed. This should help boost GRASS use for Windows.
He very recently (in the past couple days) upgraded gdal support. Please try
this out and see if the new version includes HDF support (see post by Hamish
to check this). If it does not, you can probably email Huidae and request
it. Check out his website for Windows GRASS (access from main GRASS download
site).
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Date: Mon, 14 Mar 2005 15:18:12 +0100
To: <michael.barton@asu.edu>
Subject: RE: [GRASSLIST:6142] r.in.gdal and HDF importThanks,
It seems to me that the problem arise because the gdal provided with
GRASS does not support HDF-files. - Apparently, I just need to get your
script to communicate with the DOS version of gdal...Regards,
Torkild
