On Sat, 21 May 2005, Hamish wrote:
GRASS 6 / R interface is still under active development. Also be aware
that GRASS 6 modifies the mapset's region settings to allow 3D support.
This causes trouble when you want to go back to using 5.4 after you have
been using 6.0, but is easily fixed. Hopefully one day there will be a
5.4.1 release which ignores the new 3D settings and issues an error or
warning when a raster map with 3D data is accessed.
Today I have committed a fix to the 5.4 CVS which should hopefully work around this. (Check out with "cvs -z3 co -r releasebranch_5_4")
For now it ignores any unexpected key/value pairs found in the cellhd or region file. I could probably change it to add a warning when some of the new 3-D keys are found. If the region settings are changed in 5.4 it will overwrite the WIND file, stripping out the 3-D values. But as long as DEFAULT_WIND isn't changed, this could be restored by "g.region -d" when running 6.x again. Do 3-D rasters exist yet or do the 3-D keys only
occur in the region definition (i.e. WIND file) for now?
Paul
