[GRASS5] Re: [GRASSLIST:806] Re: Live Earthquake Map: GRASS/PHP
> just some fun:
> http://grass.itc.it/spearfish/php_grass_earthquakes.php
> Recent Earthquakes: map generated by GRASS on the fly with PHP
I only suggest to generate maps from crontab every 5 min or so and not
on-fly. It would make it work faster and lower load on server.
(Imagine posting link on /. :wink:
I would ask the same for the GRASS User map on the main grass homepage.
Currently it always takes a while to load. Maybe use a cron job to
automate the thumbnail to copy/generate itself to a local file on the
webserver once a week?
Hamish
Hello Hamish,
On Wed, 26 Apr 2006 17:00:49 +1200 Hamish <hamish_nospam@yahoo.com>
wrote:
> > just some fun:
> not on-fly. It would make it work faster and lower load on server.
homepage. Currently it always takes a while to load. Maybe use a cron
job to automate the thumbnail to copy/generate itself to a local file
on the webserver once a week?
This is partly done currently. The images are locally processed and
stored on the mapserv-server, where grass.itc.it fetches them. So maybe
copying it the the websites could speed things up...
I will think about an automated exchange (via cron, scp?) between the
two servers.
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Hamish wrote:
just some fun:
Done. It is fetched a few times a day.
The new machine (grass.itc.it) offers PHP 5, so I had to
rewrite the code.
The PHP4 code example is at
  http://grass.itc.it/spearfish/php_grass_earthquakes_PHP4.php
and no longer works on that machine, not sure why (I don't
know much about PHP).
The new PHP5 code example is at
and also fails!
The debug output is:
  echo \$LD_LIBRARY_PATH >> grasserrors2.txt;
  echo \$PATH >> grasserrors2.txt;
  echo \$GISRC >> grasserrors2.txt;
which prints:
/lib:/usr/lib:/usr/local/grass-6.1.cvs/lib
/bin:/usr/bin:/usr/local/bin:/usr/local/grass-6.1.cvs/bin:/usr/local/grass-6.1.cvs/scripts
/grass0/neteler/www/spearfish/.grassrc6_ll
ERROR: LOCATION_NAME not set
I don't understand why 'lynx' works (to fetch the USGS bulletin),
also 'convert' to make JPG from PNG, but the GRASS commands fail
with 'LOCATION_NAME not set'.
ls -la /usr/local/grass-6.1.cvs/bin | wc -l
288
GRASS is there...
There is still a map shows in the PHP page as I didn't remove the
output from the last run on the old machine.
Any ideas?
rewrite the code.
and also fails!
I got a bit closer to the problem. It seems that now
the behaviour differs from
  'GISRC' => '/grass0/neteler/www/spearfish/.grassrc6_ll',
and
  'GISRC' => '/tmp/gisrc',
But the files are identical! The former gives a LOCATION_NAME not
found error, the latter "permission denied" (see above link) to
the location, although the owner of the location was changed to
apache user/group.
Mysterious. Honestly I don't understand the GISRC/GISRCRC magic in
$GISBASE/etc/Init.sh which I have to replicate somehow in the
PHP script. Earlier it was the path to the .grassrc6 which worked
on Redhat7 but now fails (RHEL4).
Any hints?
Hallo Marcus,
I do not know, how are you doing things.
I my script, I generate gisrc on-the-fly and then I export the ENV
variables. Works for mapsets owned by other users too.
svn subversion.gdf-hannover.de/.../pywps
look in file Wps/grass.py, function mkmapset
Jachym
> rewrite the code.
> and also fails!
and
apache user/group.
Any hints?
grass-dev mailing list
grass-dev@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
> rewrite the code.
> and also fails!
and
apache user/group.
But does that account have the necessary permissions? Owning the
file/directory simply means that the owner permissions are used
(rather than the group or world permissions), but those permission are
necessary.
Also, the web-server account needs execute permission on all of the
parent directories.
You don't need to set $GISRCRC. GRASS itself only uses $GISRC;
$GISRCRC should only be used within Init.sh itself (the export is
gratuitous).
