I didn’t get the column button added to the cvs somehow. I just did so and it should work now. It IS present in the tar gzip package on my website.
Michael
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Tue, 18 Oct 2005 11:45:38 +0200
To: Michael Barton michael.barton@asu.edu
Subject: Re: [GRASSLIST:8664] GIS Manager updates
Hello Michael,
your work on the GIS Manager looks great.
I’m new to Grass and such a tool makes it much easier!
I tried it out (CVS from this morning) but there are some problems with the icons:
couldn’t open “/usr/local/grass-6.1.cvs/etc/dm//columns.gif”: no such file or directory
while executing
“image create photo -file “$dmpath/columns.gif””
(procedure “DmVector::options” line 110)
invoked from within
“DmVector::options $id $opt”
(“vector” arm line 2)
invoked from within
“switch $type {
raster {
DmRaster::options $id $opt
vector {
(procedure “Dm::select” line 14)
invoked from within
“Dm::select $node”
(procedure “DmTree::select” line 12)
invoked from within
“DmTree::select .mainframe.frame.pw1.f1.frame.sw.tree [string range [lindex [.mainframe.frame.pw1.f1.frame.sw.tree:cmd gettags current] 1] 2 end]”
(command bound to event)
Best regards
Tim Semmelhaack
Michael Barton wrote:
GIS Manager updates I just committed to the CVS a set of updates to the GIS Manager.
The main functional differences are 1) a new, small window at the bottom of the main GIS Manager frame in which the GRASS display commands from all panels are listed (this was inspired by Maciek), and 2) a button for the vector, chart, and thematic panels (suggested by Markus) that can list the attribute columns of a vector file in a small window.
Appearance changes include a new, easier to read set of icons for the GIS Manager. I’ve had some problems with graphic files becoming corrupted when committed to the cvs. I think this is solved. However, let me know if there are any problematic icon gifs.
I’ve also posted the new GIS Manager files on my website http://www.public.asu.edu/~cmbarton/files/grass_gismgr/.
Michael
USAvoice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton http://www.public.asu.edu/~cmbarton
