[GRASS5] Re: [GRASSLIST:8729] Re: r.reclass not working in GUI
g.mremove is never run in a terminal; if you are using it from the
GUI, you will have to enable the "force removal" option, as there's no
way to respond to the prompt.
Any thoughts on how to get G_yes() to spawn a Yes|No GUI much like
G_percent() figures to do a Tcl thing instead of a stderr thing if it
detects it is being run from a GUI environment? Same goes for G_ask_*(),
but I'm not sure how much those are used anymore.
This would help cut down on the number of xterm kludges that d.m now
needs for various modules. Or more probably cut down on the number of
bugs like g.mremove from GUI now has.
Hamish
For simple yes/no or other questions, you can use the MessageDlg widget from
bwidgets.
Here is a simple procedure to accept input (e.g., from stdout of a grass
procedure redirected to variable msgtxt), pop up a message dialog with
yes/no buttons, and return 1 or 0 depending on whether you push the yes or
no button.
proc message_dialog { msgtxt } {
    set msg [MessageDlg .msgdlg \
        -title "The Message Dialog" \
        -message $msgtxt \
        -type yesno ]
if { $msg == 1 } {puts "no way" }
if { $msg == 0 } {puts "way to go"}
For more complicated situations like r.reclass or r.colors, there is
probably a way to make a text widget do what is necessary. I don't really
understand how to implement the wide variety of options for text widgets,
but from what I can glean from the docs (see
<ActiveState Community - Boosting coder and team productivity with ready-to-use open source languages and tools.), it
looks like you could construct an interactive interface like what is done in
the xterminal at present.
FWIW, TclTk is a very rich interface development environment (like several
others) of which GRASS uses only a very limited subset of its potential.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Sun, 23 Oct 2005 16:42:43 +1300
To: Glynn Clements <glynn@gclements.plus.com>
Cc: grass5 <grass5@grass.itc.it>
Subject: [GRASS5] Re: [GRASSLIST:8729] Re: r.reclass not working in GUI
Hamish
  if (G_info_format() == G_INFO_FORMAT_GUI)
    return !system("$GISBASE/etc/yesno.tcl");
where yesno.tcl is a Tcl/Tk program which returns 0 for yes and 1 for
no.
Having said that, programs should generally try to avoid assuming
interactive use, and take all necessary inputs from the command line.
Scripting and web applications are legitimate uses.
