[GRASS5] Re: [GRASSLIST:8999] r.statistics vs v.rast.stats vs ??
I am trying to calculate statistics such as mean elevation, slope,
maximum drainage area etc for a very large number of small plots. The
plots are in a vector file and I have been trying to use v.rast.stats
on the various rasters that represent elevation, slope, drainage area,
etc.
The problem is that the rasters are very high resolution, the plots
are quite small, and I have more than 600 to process. If you look at
the code for v.rast.stats, it converts each plot into a raster to use
as a mask and then runs r.univar on the entire map (now mostly null
values), once for each statistic. In my situation it can take several
minutes for each plot. In other words hours for each of the above
rasters that I am interested in and more than 2 days for the whole
set.
Is there a more efficient way of calculating these statistics? I have
tried to use r.statistics and can't make sense of the inputs and
outputs. Alternatively, if I could control the region size in the
critical part of the v.rast.stats script I might be able to improve
the speed of the script.
for i in $CATSLIST ; do
echo "Processing category $i ($CURRNUM/$NUMBER)"
g.remove MASK > /dev/null 2> /dev/null
r.mapcalc "MASK=if(${VECTOR}_${TMPNAME} == $i, 1, null())" 2> /dev/null
#n, min, max, range, mean, stddev, variance, coeff_var, sum
n=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f1`
min=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f2`
max=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f3`
range=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f4`
mean=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f5`
stddev=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f6`
variance=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f7`
cf_var=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f8`
sum=`r.univar -g $RASTER | cut -d'=' -f2 | tr '\n' ' ' | cut -d' ' -f9`
a couple of things,
1) r.univar is running 9 times when it only needs to be run once:
eval `r.univar -g $RASTER`
Then $cf_var gets renamed $coeff_var, needs to be carried through.
2) if g.region zoom= respects MASK, we can do:
g.region save=${TMPNAME}_rastres
+g.region zoom=$RASTER
+g.region ${TMPNAME}_rastres
done
g.remove region=${TMPNAME}_rastres
but g.region zoom= can take a _long_ time so maybe no advantage/worse?
Would need to check/reset NSRES and EWRES to raster's values or
is that redundant? (what about g.region -a?) Some checking needs
to be done that we're not screwing up the cells.. at minimum
a before/after check to see that the same answer comes out both
ways.
3) rm twice??
cleanup()
#restore settings:
g.region region=${TMPNAME}
g.remove region=${TMPNAME} > /dev/null
twice??
4) isn't -p > /dev/null circular?
g.region nsres=$NSRES ewres=$EWRES -ap > /dev/null
5) cleanup should happen before echo "Done."
Hamish
Calculating the statistics multiple times is redundant, but for my
dataset it was not slow (less than 1 second for all of them). I wonder
if my areas were larger would it take longer?
From memory (but Glynn may correct me), if the entire row is null then
a tag is saved/read so it goes very fast past those.
Maybe that is just the display driver though?
Or maybe that's totally wrong.
Hamish
