[GRASS5] Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
Hi Irek,
[compilation under Solaris]
I cc to the grass developers list for the INSTALL (install-sh)
problem below (probably 'configure' related):
On Fri, Nov 18, 2005 at 11:03:19AM +1100, Irek.Porebski@csiro.au wrote:
HI Markus,
I tried 6.1 version and I had similar problem. I have done this again
and this is the result.
GRASS GIS compilation log
Started compilation: Fri Nov 18 09:01:52 EST 2005
Errors in:
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/dbf
s2.9/include/grass \
        -o OBJ.sparc-sun-solaris2.9/dbfexe.o -c dbfexe.c
dbfexe.c:22:22: shapefil.h: No such file or directory
rootksh@theo# ll
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris2
.9/include/grass
total 12
drwxr-xr-x 2 root other 512 Nov 18 09:05 .
drwxr-xr-x 4 root other 512 Nov 18 09:01 ..
-rw-r--r-- 1 root other 2168 Nov 18 09:05 waterglobs.h
-rw-r--r-- 1 root other 26 Nov 18 09:02 winname.h
rootksh@theo# pwd
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/lib/external/shapelib
rootksh@theo# make clean
rm -rf OBJ.sparc-sun-solaris2.9
rootksh@theo# make
../.././install-sh -c -m 644 shapefil.h
.9/include/grass/shapefil.h
make: ../.././install-sh: Command not found
make: ***
[/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris
2.9/include/grass/shapefil.h] Error 127
It looks like the path is still incorrect. I have tried start this by
hand and this help a bit
rootksh@theo#/bin/sh ../../../install-sh -c -m 644 shapefil.h
rootksh@theo# pwd
.9/include/grass
rootksh@theo# ls -l
total 44
-rw-r--r-- 1 root other 17876 Nov 18 09:20 shapefil.h
Iha done the same in
/bin/sh ../install-sh -c -m 644 ../include/*.h
.9/include/
But I still connot compile it.
Started compilation: Fri Nov 18 09:21:24 EST 2005
Errors in:
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/ogr
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/base
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/db.login
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/display/drivers/XDRIVER
/XDRIVER24
rootksh@theo# cd
rootksh@theo# make
gcc -L/usr/sfw/lib
-L/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
s2.9/lib
-Wl,-R,/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-s
olaris2.9/lib -o
.9/driver/db/dbf OBJ.sparc-sun-solaris2.9/column.o
OBJ.sparc-sun-solaris2.9/cursor.o OBJ.sparc-sun-solaris2.9/db.o
OBJ.sparc-sun-solaris2.9/dbfexe.o OBJ.sparc-sun-solaris2.9/describe.o
OBJ.sparc-sun-solaris2.9/driver.o OBJ.sparc-sun-solaris2.9/error.o
OBJ.sparc-sun-solaris2.9/execute.o OBJ.sparc-sun-solaris2.9/fetch.o
OBJ.sparc-sun-solaris2.9/listtab.o OBJ.sparc-sun-solaris2.9/main.o
OBJ.sparc-sun-solaris2.9/select.o OBJ.sparc-sun-solaris2.9/str.o
OBJ.sparc-sun-solaris2.9/table.o OBJ.sparc-sun-solaris2.9/create_table.o
-lgrass_dbmidriver -lgrass_dbmibase -lgrass_sqlp -lgrass_shape
-lgrass_dbstubs -lgrass_gis -lgrass_datetime -lnsl -lz -lsocket
-lgrass_datetime -lm -lnsl -lz
ld: fatal: library -lgrass_dbmidriver: not found
ld: fatal: library -lgrass_dbmibase: not found
ld: fatal: library -lgrass_sqlp: not found
ld: fatal: library -lgrass_shape: not found
ld: fatal: library -lgrass_dbstubs: not found
ld: fatal: library -lgrass_gis: not found
ld: fatal: library -lgrass_datetime: not found
ld: fatal: File processing errors. No output written to
.9/driver/db/dbf
collect2: ld returned 1 exit status
make: ***
2.9/driver/db/dbf] Error 1
What we can do next?
These are subsequent error. We have to find the bug with the
path to install-sh. I suspect 'configure' here which contains
such a code snippet:
     ac_install_sh="$ac_aux_dir/install-sh -c"
Apparently $ac_aux_dir is set to '.' instead of '..'.
Does any list member have an idea?
Irek
BST, CSIRO IT
Queensland Bioscience Precinct
306 Carmody Road,
St Lucia, Brisbane QLD 4067
Phone (07) 3214 2333
> -----Original Message-----
> From: Markus Neteler [mailto:neteler@itc.it]
> Sent: Thursday, 17 November 2005 5:54 PM
> To: Porebski, Irek (CSIRO IT, St Lucia)
> Subject: Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
> Hi Irek,
> now I get it:
> /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/....
> you are working with the old 6.0 snapshot. Is this
> intentionally? Let me recommend to got for the 6.1-CVS
> snapshot which comes with tons of fixes (also some neded for Solaris).
> Markus
> On Thu, Nov 17, 2005 at 12:35:01PM +1100,
> > Hi Markus,
> > > It should be picked from
> > > /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-su
> > > n-solaris2.9/include/grass
> > > (last -I parameter above).
> > > Can you please check if it is there?
> > The "grass" folder doesn't exist. The last folder is:
> /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
> > s2
> > .9/include
> > > It should be copied there earlier, while compiling lib/external/
> > > Probably the 'install' fails in lib/external/shapelib/Makefile
> > > Please go into
> > > cd lib/external/shapelib
> > > and run
> > > make clean
> > > make
> > > and report what's happening there.
> > rootksh@theo# make
> > s2
> > make: ***
> [/var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-s
> un-solaris
> > The path to the "install-sh" is incorrect is should be
> > ../../../insstall-sh. How to fix this path?
> Strange! I think that it comes from 'configure', where
> 'install-sh -c' is defined. But, if possible, use the 6.1
> snapshot:
http://grass.itc.it/grass61/source/snapshot/
> Many thanks,
> Irek
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica MPBA -
Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
MPBA - Predictive Models for Biol. & Environ. Data Analysis
The configure script sets INSTALL using the AC_PROG_INSTALL macro. If
it uses the install-sh script, the path will be based upon $srcdir,
which is set by the --srcdir switch, or the path by which the
configure script was referenced if --srcdir isn't set.
If $INSTALL is a relative path (e.g. when using "./configure"), when
substituted into output files (e.g. Platform.make), it will be
modified according to the relative location of the output file (e.g.
Platform.make is in include/Make, so ./install-sh gets changed to
../.././install-sh).
If the configure script generated each Makefile from a corresponding
Makefile.in, everything would work, as the path to install-sh would be
correct for each Makefile. However, substituting into Platform.make
and including that from each Makefile won't work.
To configure GRASS correctly on a system which doesn't have a suitable
install program (AC_PROG_INSTALL ignores versions which are known to
have problems), you need to ensure that $srcdir is an absolute path,
by using e.g.:
  `pwd`/configure ...
or:
  ./configure --srcdir=`pwd` ...
