[GRASS5] Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
Hi Irek,
(cc grass5)
good to hear that the first errors are solved.
The next one seems to be related to [n]curses:
On Tue, Nov 22, 2005 at 02:15:00PM +1100, Irek.Porebski@csiro.au wrote:
There are new errors:
Started compilation: Tue Nov 22 11:06:43 EST 2005
Errors in:
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/lib/init
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/dbf
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/ogr
rootksh@theo# cd
rootksh@theo# make
gcc -L/usr/sfw/lib
-L/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
s2.9/lib
-Wl,-R,/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-s
olaris2.9/lib -o
/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris2
.9/etc/set_data OBJ.sparc-sun-solaris2.9/set_data.o
OBJ.sparc-sun-solaris2.9/mke_mapset.o OBJ.sparc-sun-solaris2.9/mke_loc.o
OBJ.sparc-sun-solaris2.9/chk_dbase.o OBJ.sparc-sun-solaris2.9/other.o
-lgrass_edit -lgrass_gis -lgrass_datetime -lnsl -lz -lsocket
-lgrass_datetime -lgrass_vask -lncurses -lm -lnsl -lz
Undefined first referenced
symbol in file
initscr32
.9/lib/libgrass_vask.so
w32addch
getcurx
getcury
ld: fatal: Symbol referencing errors. No output written to
.9/etc/set_data
collect2: ld returned 1 exit status
make: ***
[/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris
2.9/etc/set_data] Error 1
Any suggestion?
Irek
I found
http://grass.itc.it/pipermail/grass5/2004-October/015778.html
but I'm not sure if this helps.
