From 'grasslist'
On Thu, Aug 21, 2003 at 12:18:33PM +0100, Glynn Clements wrote:
Note that the g.select.pg program in 5.0.2 (and earlier) doesn't allow
you to "undefine" a host. Once you use "g.select.pg host=...", all
subsequent connections will be via TCP/IP. You can select a different
host, but you can't revert to Unix domain sockets.
To revert to using a Unix domain socket to connect to a local
postmaster process, you have to manually delete the PG_HOST entry from
the $GISRC file (typically ~/.grassrc5).
This is fixed in the CVS HEAD version, and should be fixed in 5.0.3.
Is this already fixed in 5.0.3? Where to look for that?
Not yet.
cvs diff -r 1.11 -r 1.12 src.garden/grass.postgresql/g.select.pg/main.c
--- src.garden/grass.postgresql/g.select.pg/main.c 24 Nov 2002 12:39:58 -0000 1.11
+++ src.garden/grass.postgresql/g.select.pg/main.c 28 May 2003 05:30:26 -0000 1.12
@@ -61,6 +61,8 @@
if (pghost->answer)
G_setenv("PG_HOST", pghost->answer);
+ else
+ G_unsetenv("PG_HOST");
if (list->answer) {
fprintf(stderr, _("The following databases are in the Unix catalogue:\n"));
Not yet.
@@ -61,6 +61,8 @@
if (pghost->answer)
+ else
if (list->answer) {
sync'ed into 5.0.3.
