Hi Rich,
I have added a hint concerning the env.vars on
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/index.html
-> GRASS startup
(I expect a user would check that page)
Tell me if you want it to be improved. Please note that the
env_var.html page is not yet well maintained... More input to
html/env_vars.html
is very welcome.
On Fri, Aug 03, 2001 at 10:21:10AM -0700, Rich Shepard wrote:
I cannot find reference to a preferences file. When I read the d.mon man
page I see that I can change the color depth, but that must be done manually
each time (monitorcap doesn't support this variable). Also, if I want the
default monitor window size to be larger, I have to explictly export those
variable each time, or put them in ~/.bashrc.How much trouble would it be to add a .grassrc capability to 5? User
preferences, such as monitor window size, color depth, etc. -- and I don't
even know what else it could accommodate -- could be defined there on a
user-by-user basis. That would also provide a single place for GRASS to look
for these variables.Thoughts?
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
Making environmentally-responsible mining happen.
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18
38050 Trento (Povo), Italia
tel +39 0461 314 520 neteler@itc.it
fax +39 0461 314 591 http://mpa.itc.it
