Hi Christian,
obviously the CVS is down, sorry (the entire intevation.de site)
/usr/sbin/traceroute www.intevation.de
traceroute to intevation.de (131.173.30.110), 30 hops max, 40 byte packets
19 intevation.de (131.173.30.110) 260 ms * *
cvs up README.cygwin
cvs [update aborted]: connect to intevation.de:2401 failed: No route to host
ping intevation.de
PING intevation.de (131.173.30.110): 56 data bytes
64 bytes from 131.173.30.110: icmp_seq=0 ttl=237 time=209.109 ms
Means: The server is alive, but not accepting network connections
(Hi Bernhard...)
I hope that it is up-and-running soon,
On Mon, Sep 03, 2001 at 03:24:42AM -0400, christian jeitler wrote:
Dear Markus Neteler!
The HP where the GRASS TODO list is located doesn't accept http connection.
Maybe due a crashed httpd daemon.With best regards
Christian Jeitler
christian.jeitler@web.de
e9625455@student.tuwien.ac.at
++43/699/19240377
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
