(cc grass5)
On Thu, Apr 14, 2005 at 09:40:47AM +0200, Korponai János wrote:
I am newbie on grass, but I do not find hungarian projection
system when I'm making new location. Is the implementation
possible to grass? If it is you find specifications on web:
Description Directory for EOV Projection System - Description directory of the Hungarian Geodetic Reference.Many thanks,
Sincerely yours,
Dr. Janos Korponai
West-Transdanubian District Environmental and Water Authority,
Dept. Kis-Balaton
H-8360 Keszthely, Csik F. str. 1, Hungary
e-mail: korponai.janos@nyuduvizig.hu,
http://members.iif.hu/korponai.janos
in the web I found:
http://xserve.flids.com/pipermail/proj/2004-June/001754.html
which may solve your problem. If not, I suggest
to write to the Proj4 mailing list as there are
people who certainly know the answer (and GRASS depends
on PROJ4).
There is also an open bug report, you may add yourself
to the list of observers:
http://www.intevation.de/rt/webrt?serial_num=2388&display=History
Best regards
