[GRASS5] Re: i.ortho.photo - XDRIVER bug detected
Markus Neteler wrote:
finally I could catch the error message!
X Error of failed request: BadMatch (invalid parameter attributes)
  Major opcode of failed request: 73 (X_GetImage)
  Serial number of failed request: 1194
  Current serial number in output stream: 1194
Markus and All,
This error is repeatable on Suns and intel
with
  d.zoom
  d.menu
  d.pan
  d.display
  d.rast.edit
  i.ortho.photo
The error is possibly coming from the library function
   D_popup()
I think negative window geometry is confusing it. When the
placement of the popup is off screen (even partially) some of the screen
coordinates for the popup are negative.
Place the window (mon) off to the right side of screen so the popup can
be
fully seen but parts of the display are offscreen and
d.zoom seems to work ok.
I don't think this problem is specific to either my XDriver changes nor
Robert Flor's.
I will follow this lead to fix the problem, using d.zoom as my guide.
Remember GRASS's display model was designed in 1988, much, much before
windowed environments.
It would help to update some functions such as this to be X11 centric.
Popups could become
more of what we expect, actually becoming real popups.
I believe that there are 2 classes of displays
  non interactive
    CELL
    HTMLMAP
  interactive
    4105
    IGRAPH
    IRIS
    MASS
    SUNCORE
    SUNVIEW
    XDRIVER
For the non interactive displays, the interactive bits need to be turned
off
try
   d.mon start=CELL
   d.zoom
the functions need to know something of the abilities of the display
running,
and not try to use unsupported features.
For the interactive displays, the menus and popups and window management
are all
"clunky". Sometimes we answer in the text window sometimes we answer in
the display.
Excepting for the "dumb" 4105 terminal, each of the vendors systems
(Intergraph,SGI,SUN) have
supported X11 since the early 1990's. Maybe it is time to "prune"
support for these older hardware types, in favor of better support of
X11R4 and later.
Are there any graphical GRASS users who don't use X11 out there??
C.
Carl Anderson
Fulton County, Georgia
Environment & Community Development
GIS
404 730-8026
candrsn@mindspring.com
subject 'unsubscribe grass5'
