[GRASS5] Re: information needed about Grass and TclTK (fwd)
(forwarded to grass developers' list in case anyone else can help)
I really have no idea. Sounds like a problem with your Cygwin installation. GRASS runs a lot better on Linux and it is not hard to set up a dual boot system.
Paul
---------- Forwarded message ----------
Date: Mon, 30 Aug 2004 13:13:31 +0200 (CEST)
From: "[iso-8859-1] Neuba danho" <danho_f@yahoo.fr>
To: Paul Kelly <paul-grass@stjohnspoint.co.uk>
Subject: Re: information needed about Grass and TclTK
i am trying to run GRASS and tcltkgrass for the first time.
Running startxwin.bat open two windows: one for error messge like: xfree86config is not supported, MIT-SHM disabled due to kernel support, xfree86-Bigfont disabled extension local client optimisation disabled due to lack of shared memory support in kernel etc..
in cygwin windows the following message is displayed: Run is not recognised as a internal command (translate from french)
If i try to lunch tcltkgrass by typing tcltkgrass&: the following message is displayed: Application initialization failed: could not connect to display "localhost:0", Error in startup script: invalide command name "bind"
Hoping i give you enough information.
Neuba Danho Fursy Rodelec
4 rue de l'été 1050 Bruxelles
0476313719
0032 02 650 21 38
Créez gratuitement votre Yahoo! Mail avec 100 Mo de stockage !
Créez votre Yahoo! Mail
Le nouveau Yahoo! Messenger est arrivé ! Découvrez toutes les nouveautés pour dialoguer instantanément avec vos amis.Téléchargez GRATUITEMENT ici !
