[GRASS5] Re: launch html browser as a new process & free the command line
In my case, it doesn't work because I'm using lynx as a manual browser.
IMHO, I think it's better to leave it to users to fork his/her browser.
For example, the following script will free the command line:
  my_browser $@ &
Actually, firefox returns to the shell after launching.
Thank you.
Huidae Cho
browser.
.. right. ok then, I guess we need to go back to the way it was.
his/her browser. For example, the following script will free the
command line:
  my_browser $@ &
should we expect new users to be educated in the ways of unix and
backgrounding jobs?
I'm using dillo for the task, which doesn't.
Hamish
> browser.
> command line:
> my_browser $@ &
backgrounding jobs?
No, we shouldn't. But we cannot expect users to use only graphical browsers.
Right, that depends on a browser. What about having an option or env.
var? It's not easy though. :slight_smile:
Huidae Cho
Hamish
backgrounding jobs?
Using GRASS in a non-graphical environment seems not to be very common. So I see no reason why not demanding a graphical browser as mandatory.
Backgrounding jobs should be known - > tcltkgrass &. (even I do ;-)) )
Maybe some note in the wiki should be added.
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
>>backgrounding jobs?
>browsers.
It's not about graphical environment like X-Window, but about browser
preference. :slight_smile:
Huidae Cho
Stefan Paulick
>>backgrounding jobs?
>browsers.
It must be at least selectable. There are known users (let's say,
in a major city where migration to GNU/Linux is done) who depend on
a text only version option as a requirement. If GRASS cannot be run
in text mode, they may not use it. This is a sort of minimum
requirement for them.
Please go ahead...
> >>backgrounding jobs?
> >browsers.
Eric Raymond has been working on a package to replace man pages with
XML/HTML and to change the man utility so that it can render classic
text-only "man" pages that come from XML/HTML. The benefit of this
approach is that both text-only, browser-based, and more advanced text
rendering environments can all provide 100% functionality (relative to
themselves) from 100% consistent documentation. Might be worthwhile
seeing if GRASS should plan an intercept for this approach.
I've copied Eric, in case he'd like to add anything.
M
