[GRASS5] Re: license issues
Hi all!
It seems we can proceed quickly here on the license issue
(and we should!):
Proposed action: (from Bernhard)
       - Move modules with licensing problem to src.license_problem
               until we clarify it for the next releases
Good idea. I start today.
       - Replace code for the math routines.
O.k. this is more work. Suggestion:
- move critical modules to src.license_problem
- replace critical library routines in a second step
   As this are only a few this may not be such urgent.
       - Replace LZW with a better compression
Suggestion:
- Step1
Replace the critical file
  src/libes/gis/lzw.c
with another routine but *identical* funtion headers.
This is not a nice programming habit, but can be done rather
quickly. Then publish again to remove critical source code
from internet.
- Step2
Replace the LZW-stuff totally. Needs more work.
       - Replace gif with libungif for reading and add png as better
         image format.
Should be possible.
       - Find the persons who contributed the code and ask in the
         Case of MIPS, University of Illinois and DEC.
Bill, Helena? Do you remember those CERL people? Did CERL have
contracts which might be valid?
Best regards
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1773
max: 0
Markus Neteler wrote:
Hi all!
(and we should!):
This can and should be handled by a simple disclaimer and listing of the
modules.
Suggestion:
- Step1
  src/libes/gis/lzw.c
from internet.
- Step2
> image format.
Should be possible.
Best regards
length: 1773
max: 0
length: 2677
max: 0
I am searching for a complete list (including the nets stuff that Ranjan
and
I used). Somewhere Steve and I made a list a while back. I should have
it off one of the backup tapes shortly.
Bruce
Hi all!
(and we should!):
Suggestion:
- Step1
  src/libes/gis/lzw.c
from internet.
- Step2
> image format.
Should be possible.
Best regards
length: 1773
max: 0
length: 2788
max: 0
