unfortunately there was another bug within the multiple architecture
compiling (head.$ARCH stuff):
But good news:
On Mon, Oct 30, 2000 at 05:37:10PM -0800, Bev Wallace wrote:
Markus,
I tested the new gmake5 earlier and it is fine.
However, when I run "make install", I get error messages like this:#################################################################
/home1/Grass/cvs_grass/grass/src/libes/geom
make -f OBJ.sparc-sun-solaris2.7/make.rules/home1/Grass/cvs_grass/grass/src/CMD/gmake5.0 -all
/home1/Grass/cvs_grass/grass/src/CMD/head//home1/Grass/cvs_grass/grass/src/CMD/head/head.sparc-sun-solaris2.7
- file not found (or not readable)
*** Error code 1
make: Fatal error: Command failed for target `all'
Current working directory /home1/Grass/cvs_grass/grass/src/libes/geom
GISGEN failure at STEP: src/libes/geom
This is fixed (I hope so).
cvs update Makefile.in
cvs update src/CMD
configure
Then it should be o.k.
Additionally I have fixed the bug that the first line in src/CMD/lists/GRASS
could not be commented. Now you can comment #man there.
subject 'unsubscribe grass5'
