[GRASS5] Re: make install on Multiple Arch
Hi Bev,
On Tue, Oct 31, 2000 at 12:59:26PM -0800, Wallace, Beverly T wrote:
The "make install" command now works fine.
good to know :slight_smile:
I had problems making the following programs on a Sun solaris 2.7:
(1) src/mapdev/v.geom
The if statement in the Gmakefile did not work. I don't think it is
necessary to because $(LIB_MALLOC) is already included. SGI users can
define $(LIB_MALLOC) as -lmalloc in the head file. A comment could be put
in the Gmakefile.
Hi SGI-Developers: Any ideas?
(2) src.contrib/NPS/r.in.utm
I get a complaint that it can't make -lm. In the Gmakefile, I moved the
system libraries ($(MATHLIB) and $(XDRLIB)) from LIBES and placed them at
the end of the $(CC) command.
Thanks! I have fixed in CVS.
(3) src/raster/r.binfer
Line 13 of binfer.l had a "missing translation value" error. I don't know
how to fix this.
Nor me... But it is on the list. On Linux, it compiles. We will look
for it.
Kind regards
subject 'unsubscribe grass5'
> can define $(LIB_MALLOC) as -lmalloc in the head file. A comment
> could be put in the Gmakefile.
Have configure set the $(LIB_MALLOC) variable in the head file.
Unfortunately, I have no idea how to do this. Also, since XDRLIB seems
to be never used on SGI's can we change configure to set it to blank
instead of -lsun?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I'm trying to use gmake4.3 for the first time, and it gives me the
following error:
gcc: /grass/grass4.3src/libes/LIB.linux/libgis.a: No such file or
directory
Of course there is no "LIB.linux" directory. Is gmake supposed to create
this before using it? And what about libgis.a?
Thanks!
Matthew P. Hillebrand
following error:
directory
Thanks!
Hi Matthew P. Hillebrand,
the developers of GRASS 5 are not supporting the GRASS 4.3 any more.
I highly recommend you wait a few days to get GRASS 5 beta9.
If you definitly want to use GRASS 4.3 (why?), please contact
grass@baylor.edu. They are supporting the 4.3 development.
Kind regards
Markus Neteler
