[GRASS5] Re: missing mapinfo support
On Saturday, November 22, 2003, at 12:01 PM, grass5-request@grass.itc.it wrote:
Date: Fri Nov 21, 2003 5:37:30 PM Europe/Madrid
To: grass5@grass.itc.it
Subject: [GRASS5] Missing MapInfo support in 5.0.3?
Hi there,
I just built and installed GRASS 5.0.3. I have manual pages for v.in.mif an s.in.mif, but the commands themselves don't seem to be available. Did I fail to enable a compile option? Or is this feature something that was added to the code in a subsequent version?
I'm very new to GRASS -- but I intend to use it in the midst of a MapInfo-based environment. So any pointers from the experts would be most appreciated (at the moment, I'm seeing mostly ".MAP", ".TAB", and ".DAT" files -- not ".MIFs").
I have had to deal with this difficulty because a lot of my old data and that of collaborators is in MapInfo. Both v.in.mif and s.in.mif have broken for quite some time. Unfortunately, they were never removed from the manual. To get MapInfo point data into GRASS is relatively trivial, but line and poygon data are much more problematic.
For both point and line/polygon data, make sure you set the proper projection before proceeding. Then...
For site data:
1. Create x and y columns (e.g. easting and northing for UTM's) and update them using the centroid(x) and centroid(y) function. This gives you x and y coordinates for each point. Make sure that x is the first column and y is the second column in your table. Make sure you have no empty cells (i.e., no blanks in the data; put in NA or -999 or something to indicate a null value).
2. Export your table as text, selecting Latin 1 UNIX text.
3. Use s.in.ascii to import the table into GRASS. It should all be there.
For line and poygon data (if ANYONE knows a better way, PLEASE let us BOTH know):
1. Export your data into DXF without attributes. Theoretically, you should be able to read in DXF attributes into GRASS, along with the lines and polygons, but I have been unable to get this to work. DXF files created by MapInfo with attributes will not import for some reason.
2. Use v.in.dxf to read in the data.
3. You will have to manually relabel the lines or polygons in v.digit.\
Alternate 1 for line/polygon data (and site data for that matter)
1. Export the associated data table to dbf format
2. Import the data table to PostgreSQL using pg.in.dbf. Note that current versions of pg.in.dbf can truncate longish numbers (e.g., UTM coordinates with a couple decimal places). To avoid this, redefine all fields (or at least long numbers) as text prior to export. Once in PostgreSQL, you can use the values as numbers again.
3. Use a key field to link the data values back up to the vector line/polygons
Alternate 2 for line/polygon data
1. Export to MIF
2. Convert MIF to ArcView shape file
3. Import into GRASS using v.in.shape
NOTE: MIF to vector import seems to be fixed in upcoming GRASS 5.7 using OGR import
I hope this helps.
Michael Barton
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Hi Michael,
Your MapInfo conversion instructions were tremendously helpful. Thank you so much for posting them. I was just about to go digging for the missing MIF import routines, so telling me they are broken (and intentionally omitted) just saved me a headache.
A question: Your "Alternate 2" (converting to a shape file) seems much simpler than "Alternate 1" for importing lines and polygons. Is there a downside to doing the shapefile conversion?
And everyone else: Let me echo Michael's Plea: If there's a better way, please speak up!
Thanks again,
Allan
Allan,
Not really AFAICT. If you have access to ESRI products, I think this is the best way to go currently. Remember, for GRASS 5.0.x vector files, you can only have 1 integer (i.e., cat) and 1 other value (i.e., label: numeric or string) associated with each vector file. In a shapefile import, you need to specify which fields will become cat and label. If you need more fields, you will need more copies of the relevant vector file.
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
