Hi Bob,
many thanks for your patches. I have applied them to CVS
(hope it's o.k. for all developers). The PPM format is
more common than the SGI image format. Probably a selection
window on image format would be perfect.
On Sun, Sep 24, 2000 at 10:51:04PM -0300, Bob Covill wrote:
Hello,
I am attatching to this e-mail the code I have added to NVIZ to dump
images to a PPM format. I have written out the installation steps, so
hopefully it is not to complicated.The first two files that should be incorporated are "Gmakefile" and
"gsd_img_ppm.c". These two files should be copied to
"$GISBASE/src/libes/ogsf". The "gsd_img_ppm.c" is a modified version of
the routine to dump RGB files. It creates a new library routine entitled
"G_write_ppm".
Here your Gmakefile does not fit any more to the current Gmakefile as
file name conflicts on Windows had to be fixed earlier this summer. I
have adjusted it, it compiles o.k. now.
Note the image dump routine is byte order sensitive. The file
"gsd_img_ppm.c" is currently set for a big-endian machine (eg. SUN). To
build the library on a small-endian (linux) machine comment out lines 34
to 36, and uncomment lines 38 to 40. There is a note in the code where
this needs to be done. After copying the new files execute gmake5 to
rebuild the ogsf library.
Here I have inserted a #ifdef statement.
#ifdef SUN
/*big endian*/
else
/*little endian*/
#endif
I think something with config.h to detect little/big endian would be
better than hard-code the platform names here. Feel free to modify it.
The next two files; "anim_support.c" and "init_commands.c" should be
copied to $GISBASE/src.contrib/GMSL/NVIZ2.2/src. These files will
overwrite existing files. These files utilize the above PPM lib routine
and create an NVIZ command entitled "Nwrite_ppm". This is the command
that will be called from the nviz scripts. After adding the above two
files, execute gmake5 to rebuild the NVIZ2.2 executable to incororate
the new command.After completing the above, three TCL scripts can be modified to execute
the new dumping routine. The scripts are; "nviz2.2_script",
"panel_animation.tcl", and "panel_kanimator.tcl". I have also attached
these three scripts. They can be placed in
$GISBASE/src.contrib/GMSL/NVIZ2.2/scripts.With the above changes execute gmake5 from
$GISBASE/src.contrib/GMSL/NVIZ2.2 to install the updated scripts in the
proper location.Images should now be dumped to a *.ppm format.
Yes, working o.k. on Linux (no bad magic number problems!).
If there are any problems or questions let me know. I have built and
used the routines on both a Sun Sparc and Linux.
Bob CovillTekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
CanadaE-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Many thanks, Bob. Your contribution will become part of the next GRASS 5
release.
Kind regards
Markus Neteler
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
subject 'unsubscribe grass5'
