Bob,
thank you for all the nviz updates - I finally got around to test
it all myself and it all looks great and I suggest to include it
into GRASS5.0.2
I did not have a chance to test thoroughly the load/save 3d view option
although it seems to work OK (except for the GUI update) - maybe
somebody who uses 3dview could test it further.
The animations could be tested more too but we will be doing that
within next week or so. The tilt, accelerated rendering and the
setting of center via canvas work great.
I found 2 cases when nviz crashes (all old that have been there
from the very beginning):
1. If the user draws a cutting plane through multiple surfaces
with color from top or bottom surfaces and at least one of the surfaces
has different resolution than the other ones, nviz crahses. This is
already in bug tracker.
2. If the user tries to drape a vector layer that is outside the current
region it gets pretty nasty with tons of messages like this
dv = 38022496.000000, dh = 38022496.000000, dd = nan
stuck on 0
cv = 0, ch = 0, cd = 0
untill it crashes. I will file a bug report, unless somebody has
already tried to fix it (it should just give an error message)
There are 3 other unpleasant behaviors that seem to depend on what
kind of graphics card you use:
- vectors not draping properly on some machines
see
http://skagit.meas.ncsu.edu/~helena/grasswork/grassprobl/
- multiple surface overlay changes with distance
compare
overlayclose.jpg and overlayfar.jpg (these are the same surfaces,
I only zoomed-out)
- clip works differently on dif. machines - farther views are
still heavily clipped on some machines, but there are no problems on
others.
I will investigate here more - I have 5 different graphics
cards to try it on so I should be able to tell where it works
and where it does not, although I am not sure whether anything
can be done about it.
thank you once more (the handy help button is great too - we can help
with tutorial updates if you want and I definitely need to update the
TODO-BUGS
list)
Helena
Bob Covill wrote:
Markus,
I have attached the updated NVIZ files for you to look at. I just
grabbed the files that CVS was telling me had changed.This should have the white background at startup, plus other changes
previously mentioned.I have enabled the 3D-View stuff (no compile flag). It seems to be
working. I am sure there will be some issues with it. One of the biggest
problems is that there is currently no way to update the GUI to match
the loaded 3D view. The "load state" option does this but it is
resrictive to that file format. On my ToDo list is write a function that
sets the GUI from the current scene.I have added another Help option to the GUI. I converted the TODO / BUGS
file to HTML and moved it into the html directory. There is now a link
to this from the GUI. The idea is that we can update Helena's list
sometime, and give users a good idea of what is and what is not working.
In doing this I noticed that alot of the HTML in the existing tutorial
needs a lot of cleaning. Add to the ToDo is update manual and tutorial.Let me know if you have any questions.
Bob CovillTekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
CanadaE-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498------------------------------------------------------------------------
nviz_new.tar Type: Unix Tape Archive (application/x-tar)
Encoding: base64
Download Status: Not downloaded with messageName: ogsf_new.tar
ogsf_new.tar Type: Unix Tape Archive (application/x-tar)
Encoding: base64
