Markus Neteler wrote:
On Fri, Apr 20, 2001 at 10:38:26AM -0400, Frank Warmerdam wrote:
> Folks,
> I have prepared a PROJ.4.4.3 source release. This release includes:
[nice news removed]
Congratulations, Frank! The next step for us (GRASS Development Team)
will be to syncronize GRASS/PROJ and PROJ4 to make it a plugin...
Thank you for all your work,
Markus,
I would be willing to play a major role in this, presumably within GRASS 5.1.
In addition to using PROJ.4 as a shared library, rather than including a
copy within the GRASS source tree, I would also like to iron out a few
quirks about the PROJ-like definition of projections in GRASS to bring it more
into line with the core PROJ schemes (partly modelled on how things are done
in GRASS).
I would also like to review how datums are handled now in GRASS to see if
the PROJ mechanisms can be used more directly.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
subject 'unsubscribe grass5'
> > Folks,
> [nice news removed]
Markus,
in GRASS).
Frank,
you are welcome!! The change might be pretty simple: The GRASS/PROJ wrapper
routines are in
grass/src/libes/proj/
Gmakefile
do_proj.c
get_proj.c
All the other files are (old) PROJ4.2.x files as far as I can see. So a
simple change to Gmakefile and libproj4 stored in $GISBASE/lib should
do along with changed Gmakefiles of s./m./r./v.proj.
The datum support is definitly for 5.1 and hopefully possible to integrate
into the wrapper functions (if we want to keep them).
Regards
