> > Then do dpkg-checkbuilddeps to see the additional packages you
> > will need to compile it. They ought to put this where you can see
> > it before you download. [Took several wget -c's throughout the
> > night just to find out.]:
I also corrected the fftw3-dev -> fftw2-dev (as GRASS requires FFTW2,
not FFTW3).
the needed debian package is actually called fftw-dev (fixed).
The debian control and rules files are currently in active development.
Please report any problems, I don't have time right now for exaustive
testing.
my current list: (grass 5.7-cvs)
Build-Depends: bison | byacc, c-shell, debhelper (>= 4.0.2), doxygen,
fftw-dev, flex, lesstif2-dev, libc6-dev, libfreetype6-dev, libgdal1,
libgdal1-dev, libjpeg62-dev | libjpeg-mmx-dev, libncurses5-dev,
libpng12-dev, libreadline4-dev, libtiff4-dev, postgresql-client,
postgresql-dev, proj (>= 4.4.7), tcl8.3-dev, tk8.3-dev, unixodbc-dev,
xlibmesa-gl-dev, xlibmesa-glu-dev, xlibs-dev, zlib1g-dev
libgdal1 and postgresql-client packages really needed for build?
Hamish
