[GRASS5] Re: polygon cleaning
[v.clean was very slow on a huge & complicated imported shape file of areas]
On Wed, 11 Feb 2004 Radim Blazek <blazek@itc.it> wrote:
> > Try somehow find the type of data causing the problem.
> > Now I have just one idea, because the areas are probably isolated,
> > it could be that exist one BIG boundary around all the map
> > (I thing that something like that exists in ArcInfo),
> > in that case, when this boundary is processed, it selects
> > lines which could intersect it by bounding box, in that case ALL
> > lines, and to check intersection of ALL segments of that BIG line
> > with ALL segments of ALL other lines can take a very long time.
> > Is it clear explenation?
> Yes, clear explanation, but not the case.
Why not? I think it is. Not just one BIG, but many big. The problem is,
that areas are big, and do not share boundaries, so bounding box of
one such big area is big and selects many other boundaries.
I have got idea. Split boundaries to smaller parts, something like
for ( line = 1; line <= Vect_get_num_lines ( In ); line++) {
    type = Vect_read_line ( In, Points, Cats, line);
    v = 0;
    while ( v < Points->n_points ) {
        Vect_reset_line (OPoints);
        for (i = 0; i < maxvertex && v < Points->n_points )
              Vect_append_point ( OPoints, Points->x[v], Points->y[v], 0);
        Vect_write_line (Out, type, Points, Cats);
Could you try it? If it helps, it would be reasonable to add this splitting
to v.in.ogr / v.clean.
[haven't tried it yet]
Could this also help to speed up the "Breaking Lines" step in v.overlay?
hint for the archive:
Running v.select first (very fast) helps speed up v.overlay (very slow).
Hamish
