Michael,
[I changed grass-admin to grass5 address]
On Wed, Apr 06, 2005 at 05:35:18PM -0700, Michael Barton wrote:
I¹m having a problem with r.fill.nulls that I think is somewhat different
from the ones previously reported. The problem is that it goes through the
process of doing the interpolation, but somehow never makes the map to
patch. Below, I list the output from the script when trying to fill the
nulls in an SRTM DEM. I¹m running it on 6.1 cvs from 26 March on a Mac OSX.
I¹ve tried it in both x11 and aqua versions with no difference. I WAS able
to do this a couple weeks ago. Any suggestionsMichael
= = = = = r.fill.nulls output = = = =r.fillnulls input=SRTM_u03_p198r033 output=SRTM_u03_p198r033_fillnul
tension=40. smooth=0.1
Using tmp file r_fillnulls_1236
Percent complete:
GRASS_INFO_ERROR(1266,1): Key column type is not integer
-> here is the problem!
You probably got into the dbfdriver trap: I was updating the
shapelib in GRASS to GDAL 1.2.6. But there is a bug in the dbf driver
in GDAL which made integer columns to floating point columns.
This bug was present over one weekend, then I discovered it
and reverted.
http://grass.itc.it/pipermail/grass-commit/2005-March/017090.html
Later I updated again to 1.2.6 along with a bugfix
suggested by Frank:
http://grass.itc.it/pipermail/grass-commit/2005-March/017113.html
http://grass.itc.it/pipermail/grass-commit/2005-March/017114.html
Please update your installation and report again.
From other users I know that it works (no time to try myself
today).
Hope this helps
