Hi Jaro,
(cc grass5)
On Wed, May 22, 2002 at 03:20:55PM -0400, Jaro Hofierka wrote:
Markus,
I replaced main.c and bordwalk.c in r.proj and it works now. I have used
versions from mid-March release. Later I'll try to figure out what is
wrong there.
Did you also try v.proj? The same problem occurs for me (in any
location, even the old ones).
Markus Neteler wrote:
Hi Jaro,
(cc grass5)
Markus,
I replaced main.c and bordwalk.c in r.proj and it works now. I have used versions from mid-March release. Later I'll try to figure out what is wrong there.
Yes, it works OK. But I had to replace recent source files found in r.proj, v.proj, s.proj by older versions from CVS snapshot experimental dated March 15.
J.
