On Thu, Dec 13, 2001 at 11:53:35AM +0100, Morten Hulden wrote:
Hi Markus,
this is not on the artifacts but on the 1-pixel shift:
On Wed, 12 Dec 2001, Markus Neteler wrote:
> - might be shifted by 0.5 to 1 pixel (not sure!)
I suggested a fix for this, Markus. Did you try it?
Hi Morten,
sorry, I did not try (at time in Germany away from my data).
I have been looking at that code portion and was not sure
about it (the confusing index).
I will apply the bugfix now.
> In r.proj/cmd subroutines nearest.c (and bipolar.c and cubic.c) change
> the lines> row = (int) (*row_idx + 0.5);
> col = (int) (*col_idx + 0.5);> to
> row = (int) (*row_idx);
> col = (int) (*col_idx);> If this helps, of course the correct fix would be to delete the lines
> from the subroutines altogether, and make the type cast in main.c
> instead, and declare row_idx and col_idx as integers. (row_idx and
> col_idx are not used as floats anywhere, so why declare them as such.
> but changing them requires changes in function declarations and
> r.proj.h as well, so go for the easy test above first)I am very sorry but I cannot get my grass installation to work so right
now I can't test it myself, though I would really like to get it going
again.But I have very little time to play with the installation process. How do
you get the socket-driver to work? Shouldn't there be a makesockets.sh
script included somewhere?
The socket driver is default and plug-and-play nowadays. Do
you face problems to get it running?
