[GRASS5] RE: [R] using Rterm under cygwin, no possiblity to delete characters
On Fri, 30 Jul 2004, Dewez Thomas wrote:
Dear R-users,
Thanks to Roger Bivand, it appears that the real problem is coming from the
way R talks to X11 under cygwin. Both other invocations of Rterm, either in
a bash window without Xwindow capability or from the DOS command, work just
fine.
Rterm breaks down every time it is invoked from a bash shell inside an
Xwindow session. The symptoms are the following:
+ No popup window appears when invoking help() or plot() commands
+ Instead, the Windows task bar shows an R icon, but this icon cannot be
restore to full screen
+ Rterm dies when hitting return after correcting typos
the error message then is:
Error: syntax error
Execution halted
This suggests that Rterm is by-passing fvwm2 and the X11 environment to talk
to windows directly. This is also probably the reason why terminal
properties are forgotten when just using Rterm for typing commands. It
forgets that it was invoked from bash and responds to all the keys pressed.
If typos are corrected with backspace, Rterm reads is a gibberish string
made of printable and non printable characters causing it to misunderstand
the command and fail.
Any clues as to what I should do? I insist on using R in an Xwindow session
because I want to take advantage of the R/GRASS module and compute stats on
GIS layers.
I'm afraid that this is close to impossible. Rterm will run for the
Generic GRASS Cygwin version (I have tried with GRASS 5.0.2), but
not pretending to do X11 under Cygwin. Note also that Glynn Clements has
commented on the GRASS developers list that X11 Cygwin for the GRASS 5.7
"new generation" beta is very untried and highly risky in any case.
Can you try to run what you need using generic when you need R, and revert
to X11 when you don't need R? Then you can control the interaction between
the different parts of your software without having them all trying to run
at once.
This is really a GRASS development issue for Cygwin users, since it is
known that R under Windows and Cygwin are not compatible, and that R for
Windows is only for Windows (as the name suggests).
Roger
Thomas
Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient néanmoins de
vérifier l'absence de corruption à sa réception.
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
______________________________________________
R-help@stat.math.ethz.ch mailing list
https://www.stat.math.ethz.ch/mailman/listinfo/r-help
PLEASE do read the posting guide! http://www.R-project.org/posting-guide.html
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
