Hi Helena,
We're migrating to Solaris 8, but even its stable release has
network issues with DNS and DHCP. Hopefully I can have
a Solaris build by tomorrw. I'm updating the README's
and everything else as well. I'll keep you posted on my progress.
Already worked out some of the library incompatabilities. It
looks like when you do like we have here having both 32 and
64 bit OS's installed on the same machine, that's where the problems
arise. I'm compiling a list of the offending files.
Other than Mesa, I'm using Tcl and Tk 8.3. That should do
you nicely. Just be sure you've got wish8.3 aliased to just
wish tho'. Otherwise you'll run into problems. I haven;t found
any Tcl widgets that aren;t downward compatible...yet.
Bruce
Helena Mitasova - staff wrote:
>Solaris 7 32 bit has trouble finding zlib's located in
>/usr/local/. I've had to hard wire this to get a compile
>to go. Any quick fixes already or should I dig deeperBruce,
have you tried Solaris 8 - supposedly it is better than 7
and it may not have a problem. I was told that Sun is
encouraging users to switch from 7 to 8 as it has lots of
fixes so it may be better to compile for for 8.Helena
P.S. I haven't tried to install GRASS on the Sun that I have
here yet but I plan to do it as soon as you post the binaries -
I appreciate that mesa is there too - is there anything else
that I need to install (I have tcltk)?
subject 'unsubscribe grass5'
