just to report some minor bugs:
- g.mlist does not work on IRIX.
It just puts out a long listing of fragments of the shell script itself.
Had no time to look into that.
It's strange.. There is no code to do that.
- with d.pan and d.zoom the color of vectors is always restored white.
If you draw a map with a e. g. green vector and zoom/pan, the vector is
re-drawn, but always white instead of the initial green.
There must be something wrong with the R_pad contents, as d.save puts
out the correct color with the vector before calling d.zoom/d.pan, but
afterwards the color is white even in the pad structure, so that d.save
puts out "d.vect vect=vect@PERMANENT color=white".
Now default behaviour is to use correct colors. -j flag is used to redraw
maps using command's default color.
Yours,
Huidae Cho
subject 'unsubscribe grass5'
