[GRASS5] Re: src/libes/gmath
On Sat, Sep 01, 2001 at 12:43:22AM +0100, Glynn Clements wrote:
Markus Neteler wrote:
> I am testing on CRAY, but...
> cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c fft.c -o
> OBJ.alpha-cray-unicosmk2.0.5.X/fft.o
> CC-11 cc: ERROR File = fft.c, Line = 67
> The indicated directive is not a recognized preprocessing directive.
> #warning fft() not implemented; requires FFTW library from www.fftw.org
> Total errors detected in fft.c: 1
> Make: "cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c fft.c -o
> OBJ.alpha-cray-unicosmk2.0.5.X/fft.o": Error code 1
> cmd-2436 make: Stop.
> Sorry for this, but it needs to be modified again...
OK. I'll just remove the #warning line; configure should have
generated a warning if fftw wasn't found, and i.fft, i.shape and
r.surf.fractal will appear in error.log.
> BTW: Does it make sense to move the remaining matrix functions from
> src/libes/gis to gmath?
Probably. lu.c (G_ludcmp, G_lubksb) and eigen_tools.c (G_tqli,
G_tred2) could move to gmath.
Glynn,
thanks for your fixes. Concerning jacobi.c: Is the same functionality
eventually already provided in eigen_tools.c (just guessing, I can talk
to a colleague on Monday)?
The main issue in forming a common vector/matrix library is converting
existing code to use a common format. So far I've encountered four
formats:
1. "double **a", zero-based: gmath/eigen.c, gis/eigen_tools.c,
gis/lu.c, i.pca.
2. "double **a", arbitrary ranges: r.param.scale
3. "double a[MX][MX]", one-based: gmath/jacobi.c, i.cca
4. "mat_struct *a": la.c
The main problem with using a structure is that most of the existing
code uses "a[i][j]" to access matrices.
Sorry, no idea here (hi developers!). But it should be conform...
Concerning CRAY and directives:
grass-commit wrote:
Remove #warning from gmath/fft.c
What about a platform sensitive switch (ifndef __CRAY__) or so to allow
such #warning for all other platforms? Another #warning also in la.c.
On the other hand "configure" is chatting.
If I'm correct in the belief that jacobi() finds eigenvalues and
eigenvectors, then this should already be provided by eigen(), which
is just a wrapper around G_tqli and G_tred2.
It's hard to get the logic exactly right. And configure already
provides a warning (which could be made into an error, but there are
only 3 programs which need fft()).
I'll remove that.
