On Mon, 17 Jan 2005, Markus Neteler wrote:
(cc grass5)
On Mon, Jan 17, 2005 at 02:37:44PM +0100, Roger Bivand wrote:
> On Mon, 17 Jan 2005, Roger Bivand wrote:
> ... and also wanted show that rastput() would scale well to much finer
> grids - which it does - and found a bug in rastput() and other functions
> that has led to the layer being written to the GRASS database with the
> wrong window if system("g.region ... ") is used. This is the same bug that
> affected gmeta() until Bodo Ahrens found it 18 months ago. The problem was
> that the GRASS library function tries to be too clever (I think disk
> access was very slow when it was written), and stores a local version of
> the data in memory in a cache of sorts. It does not check, though, whether
> the data on disk have changed - it just returns the cached values! Using a
> lower-level function, and conditionally altering G__init_window () seems
> to have fixed it. The new version should reach CRAN soon.
Roger,
is there any change which should go into GRASS-CVS?
G__init_window () in src/libes/gis/window_map.c does the same as in my
local copy, that is calls G_get_window (), rather than G__get_window ().
What usually causes trouble for non-exiting use of libgis.a is the number
of places things are saved in a global variable (like G__.) which do not
get refreshed when the data on disk change. You can see it happening in
G_get_window () and its use of static int first (get_window.c), which uses
the cached dbwindow without checking the disk version write time. My guess
would be that I don't loose much in time by doing G__get_window () always,
but this time I hadn't realised that G__init_window () called in opening
and closing cells imposes the stale header, from G_get_window ().
Is checking the write time faster than just reading the current window? If
so, G_get_window () could be altered to record its last refresh time, and
if the window had been written since then, re-read. If not, G_get_window ()
should just read anyway. How would this play when the GRASS database is
across a network?
The changes I've made are in the modified 5.0.* libes/gis sources within
the R-GRASS interface package. I can run some diffs, most of the changes
are things that don't matter at all if one user is running a single GRASS
program at a time on the database, but do matter when read, cached data
are used stale (now window, mapset, other environment variables, some
other things too if I remember right). Changing g.region through system()
from the R prompt changes the disk file, but the loaded G__. stayed
blissfully unaware of the change with G_get_window (), only G__get_window ()
forced a read.
Roger
> statsgrass mailing list
> statsgrass@grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
