[GRASS5] Re: TclTkGrass: default directory
On Wed, Nov 15, 2000 at 02:24:34PM +0100, mlennert@club.worldonline.be wrote:
Hello,
How can I change the default directory to which the 'file' buttons open the
file browser ? Right now it always opens to /usr/games...
does anybody has an idea? If you use in tcltkgrass:
Import-> Raster map -> something
and hit the file button, it is not the current
directory (but it should).
For Moritz it is /usr/games, on my machine /usr/openwin/bin.
Must be a problem in src/tcltkgrass/main/gui.tcl
Thanks in advance
subject 'unsubscribe grass5'
Markus,
is it ok if the home directory is used?
This would require that the enviroment variable HOME is set.
Everything else (how do you define the 'current' directory? The one you
are in at startup of tcltkgrass?) would be complicated.
cu,
Andreas
> Hello,
Thanks in advance
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
On Wed, Nov 15, 2000 at 08:29:30PM +0100, Andreas Lange wrote:
Markus,
This would be perfect. I think it was working like that in
past. Since Moritz comment I am aware that it is not the
tcltkgrass startup directory any more.
But HOME is o.k., better than /usr/games :slight_smile:
Thanks for loking into that,
cu,
Andreas
> > Hello,
> Hi all,
> Thanks in advance
> Markus
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Hi all
> Markus,
I just fixed the bug. It was the search for wish at the beginning of
tcltkgrass which changes directory to try and find wish files. I simply
saved the current directory before the search and then cd'd back after.
The default directory for the files button is now the directory you
started tcltkgrass from.
Let me know if there are any problems.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
maybe $LOCATION would be appropriate?
> Markus,
-- ebm
| Eric B. Mitchell mailto:emitchell@altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
              ,___
          /"\ / o=\ /"""---===/
         / \_/ \__/ ---===/
         | //\ || /""TT""/ //\ || ||""\
         | // \ || || // \ || ||__/
         | //--==\ |L--/ || //--==\ || || "=,
           \____---===/
Hi Eric,
maybe you did not get the mail due to the server problems here
last night: Justin already fixed this bug. Now it's opening
the directory where tcltkgrass was started.
Regards
> > Markus,
-- ebm
              ,___
         / \_/ \__/ ---===/
           \____---===/
