On: Mon, 19 Feb 2001, John Huddleston wrote:
Subject: Re: [GRASS5] vt100 error with osx + xterm error
Justin,
I get that same message using Cygwin. I checked the
/usr/lib/terminfo and all is well there. I'll look at the
initscrJohn Huddleston
Well, I fixed the error for Cygwin. It turned out that the
/usr/lib/terminfo directory was a symbolic link to the
./share/terminfo directory. I removed the symbolic
link, moved the share terminfo directory to /usr/lib and
created a symbolic link from share to ../lib for the
terminfo directory. No more error message. That's
a weird one. It might be because I am using the X-win32
server from StarNET. Programs compiled outside of
Cygwin do not recognize the Cygwin symbolic links. The
xfree binary should work OK.John Huddleston
I just looked, and I do not have a /usr/lib/terminfo, in fact there is not a terminfo anywhere on my system. Could that be the problem? How might I create such a file?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
subject 'unsubscribe grass5'
