[GRASS5] Re: v.in.shp on solaris2.7,5.0.0pre3
John Gillette wrote:
Good Morning,
v.in.shp only works for me on the small test files located in
.../grass5.0.0pre3/src/mapdev/v.in.shp/test:
  circles.shp
  islets.shp
  simple.shp
On bigger files, it stops in the middle.
Currently v.in.shape is a memory hog, as it builds huge monolithic structures in memory. On some systems this may be critical, and it also depends on the resources available. Can you say - what happens in the middle of an import, when it stops?
David
> Good Morning,
> circles.shp
> islets.shp
> simple.shp
Hi David,
do you foresee an update to the topology engine to work segmented (in
5.1)?
At time I have to process a 300000 lines SHAPE file, 1GB is far from
being sufficient for v.in.shape. I am asking you as we discussed the
memory problem some time ago.
I have successfully plugged in the SHAPE into 5.1, but v.build
eats all memory. Also 5.0 processing is impossible.
I volunteer for testing new versions :slight_smile:
Good Morning,
circles.shp
islets.shp
simple.shp
Hi David,
5.1)?
There are two approaches to the problem of very large files. I am not quite sure what constitutes `average', `normal' or `professional-level' specs in workstation terms these days, but there is a limit, as we know, to the size of files that v.in.shape can import, and this limit is currently unrealistically severe.
1) There is the question, which really is much more general than the problems of import/export, of dealing with small areas at a time, in a way that allows optimal use of resources, but yet is transparent to the end-user (even the module-developer). I think this is a reasonable definition of the question of `segmentation'.
2) The problem of adequate use of disk-access where the problem in hand exceeds the resources of the available memory.
I foresee (but it may be a mirage :slight_smile: ) that attacks on both of these are possible for GRASS 5.1. In the case of disk-access, then even for the stable release, the use of dbm should solve the problem of large file imports.
I have successfully plugged in the SHAPE into 5.1, but v.build eats all memory. Also 5.0 processing is impossible.
The techniques for segmented import would also provide a new means of building and maintaining topology. So, the problem of making v.build efficient and effective is largely the same as that of solving the import problems.
This will be the next development after the shape/mif import filters are ready, and it builds on principles already incorporated in these. Currently I'm concentarting on getting these ready. There will also be - shortly afterwards - versions for 5.1, where the main difference will be in importing multiple categories to the new format.
David
